Restoration & Repair Tips Board
pittman arm
ricedaddy
12-02-2005 10:56:56
Can anyone tell me the best wood to make a pittman arm out of?
Thanks for your help
Ron
ricedaddy
12-03-2005 14:26:07
 Re: pittman arm in reply to ricedaddy, 12-02-2005 10:56:56
thanks so much for the info guys
Ron
Rnicholas
12-02-2005 15:53:13
Hickory is best--it has more flex but is still plenty stout. Make sure you have no knots and while you're at it, make an extra one for later.
Bob
12-02-2005 11:38:22
Many farm supply stores sell generic pitman sticks quite reasonably.
If they don't have one for your application, you could get a longer one, and cut and drill it to fit quite easily, and have a good quality replacment with only a little work, and not much $$.
old
12-02-2005 11:12:54
I've made them from oak and also hicory. Both woods worked well for me. Just make sure theres no knots in the piece you use
JD9295
12-03-2005 21:09:21
 Re: pittman arm in reply to old, 12-02-2005 11:12:54
i make mine from oak fom a local kiln, letthem soak in used oil for a week or so then in the sun then wrap it with fiberglass tape. might not help but it seems to, it will still break if it needs.
And like mentioned in another post here, make 2 while your at it.
