Restoration & Repair Tips Board
radiators
go21cl
11-27-2005 07:53:13
I have a ford 2000, has always cranked fine, but has a bad radiator. After removing the radiator, I tried to crank it to move it a few feet back into the shed, but it will not crank. Will removing a radiator prevent one from cranking? Thank you.
old
11-27-2005 08:55:17
 Re: radiators in reply to go21cl, 11-27-2005 07:53:13
Short answer no it will not. But when you did that you probably pulled a wire off or messed something else up.
go21cl
11-27-2005 09:54:06
 Re: radiators in reply to old, 11-27-2005 08:55:17
Thats what I was afraid of, but I saw no wires dangling.
old
11-27-2005 10:41:57
 Re: radiators in reply to go21cl, 11-27-2005 09:54:06
All it takes is knocking one a little loose and it may not even drop off enough for you to see. You will need to look at all the wires from the switch to the starter and also the ones from the battery to the switch.
go21cl
11-27-2005 12:29:15
 Re: radiators in reply to old, 11-27-2005 10:41:57
Ok Thanks
Jon Hagen
11-27-2005 16:22:02
 Re: radiators in reply to go21cl, 11-27-2005 12:29:15
Not familiar with a Ford 2000,but might it have to be in nuetral or clutch depressed to crank ?
go21cl
11-27-2005 18:38:50
 Re: radiators in reply to Jon Hagen, 11-27-2005 16:22:02
Not sure if it does or not, but I always do those things before I start it, but nothing works now.
