Restoration & Repair Tips Board
Rear main seal replacement-insert to bolt
olsons
11-22-2005 09:21:16
Hi. Does anyone have the directions to replace the insert rear main seal to a bolt rear main seal on the Massey tractors? Thanks in advance for the help.
olsons
11-22-2005 10:47:44
 Re: Rear main seal replacement-insert to bolt in reply to olsons, 11-22-2005 09:21:16
Thanks-that is exactly what we needed!
george md
11-22-2005 10:28:29
Olson, Sounds like your working on an H or J series continental. Hold bolt in seal in place with crank installed , mark the holes , remove crank, drill and tap for 1/4 -20 bolts, put gaskets under seal halves and bolt in place. Shout if you need more info.
george
