Restoration & Repair Tips Board
TO-30 water in hydraulic fluid
Ken O'Connor
11-21-2005 12:42:58
My old TO-30 gets water in the hydraulic fluid reservoir, from the cooling system. How is it getting there? Is there a freeze plug that you access by splitting the tractor? I made a temporary fix by installing a petcock in the drain plug, to let the water out periodically, but would like to repair it correctly. Any and all help would be appreciated. Thanks and God Bless.
Ken
JCS-OHIO
11-28-2005 10:15:04
 Re: TO-30 water in hydraulic fluid in reply to Ken O'Connor, 11-21-2005 12:42:58
.... and if you are getting so much as to have to drain it periodically, it probably isn't just condensation. You probably have some bad gaskets or a crack in a casting... J.
MSM
11-24-2005 13:41:36
What you are seeing in the transmission is rain water or condensation.There is no way for coolant to get in the trans/rear end.
jimmie
11-30-2005 08:30:54
 Re: TO-30 water in hydraulic fluid in reply to MSM, 11-24-2005 13:41:36
more than likely you need to replace the rubber boot on the shift lever. this is the most common cause for water in hyd. fluid
