Restoration & Repair Tips Board
Removing 10 coats!!!
wayne2
11-21-2005 09:14:07
Sheet metal-small amt. gas oil mix in oil pan,set metal over,light it off, blisters paint-hit w/putty knife-wire brush-dirty but effective. less than cup of gas please!!!!!
rustyj14
11-26-2005 10:07:24
 Re: Removing 10 coats!!! in reply to wayne2, 11-21-2005 09:14:07
I use a product called "Aircraft stripper". Available at some local auto paint stores in my area. Ask for it at hardware stores. It will soften up at least 4 layers at a time. When done, wash off with cold water and let dry. then wash with mineral spirits, and prime. May want to wash with Metal-prep before priming, but not necessary! Rusty
Leland
11-25-2005 19:43:43
Try using zip strip then all you need is a putty knife and a wire brush works good .
RustyFarmall
11-21-2005 20:56:00
I use a Wagner heat gun and putty knife. Don"t get the gun too close or hold in one spot for very long or the paint will ignite.
wayne2
11-23-2005 15:27:41
 Re: Removing 10 coats!!! in reply to RustyFarmall, 11-21-2005 20:56:00
That'd be good-but my way I stand away from lead based paint-while smoking cigg. LOL W
