Restoration & Repair Tips Board
ford jubilee
j forrester
11-21-2005 07:30:25
would like adjustment settings for draft and position control on hydraulic lift ---inch---
Dan
11-21-2005 11:48:37
 Re: ford jubilee in reply to j forrester, 11-21-2005 07:30:25
I can do you one better - a document with all the info PLUS step by step proceedures in easy to understand language WITH pics. Plus, a lot of shortcuts and tips.
Thanks to our own Ramrod for this great document for NAA owners.
Good luck,
Dan
alg
12-09-2005 07:25:02
 Re: ford jubilee in reply to Dan, 11-21-2005 11:48:37
Dan will this also work with the 100 series?
Jubal Lee
11-21-2005 22:37:51
OOPs! That Document won't open on my browser!
Dan
11-22-2005 14:04:05
 Re: ford jubilee in reply to Jubal Lee, 11-21-2005 22:37:51
Replace the "%20"'s in the link in your browser window to spaces and see if it works then. If it still won't send me an email and will email you the doc (it is pretty big though).
Dan
j forrester
11-23-2005 06:44:23
 Re: ford jubilee in reply to Dan, 11-22-2005 14:04:05
dan----- what is cnh dealer (parts)
Dan
11-26-2005 06:54:33
 Re: ford jubilee in reply to j forrester, 11-23-2005 06:44:23
Case New Holland - they are the ones that bought out Ford's tractor division (well, New Holland), and where you can still get parts from for the older Ford tractors.
HTH,
Dan
forrester
11-27-2005 09:31:16
 Re: ford jubilee in reply to Dan, 11-26-2005 06:54:33
lift-----all draft adj.ok can not adj.position to proper setting -----
Dan
11-28-2005 07:28:25
 Re: ford jubilee in reply to forrester, 11-27-2005 09:31:16
Did you read the adjustment doc I posted a link to? Sometimes the triangular plate that sits between the big draft control spring sticking out the back and the lift cover gets worn down. This will throw your position control measurements off after you set the draft control spacing. You can still get this part new from a New Holland dealer.
I will not lie to you, it is a precise adjustment and took me 4 or 5 tries to finally get mine right. Don't give up, go back and start over from the beginning and double check all your steps and specs. If after several tries you still can't get it to come into spec - split the difference between the draft and position control measurements to get it as close as possible and call it a day (or of course start buying new parts to get it into spec).
Good luck,
Dan
jforrester
12-04-2005 19:45:49
 Re: ford jubilee in reply to Dan, 11-28-2005 07:28:25
thanks dan used your doc. hyd. lift works perfect.....
Jubal Lee
11-21-2005 08:17:25
You should be able to find what you need here:
Link
Good luck!
