Restoration & Repair Tips Board
ignition
K L Cullingswor
11-16-2005 16:25:26
I am helping an older fellow fix up his 9N. I want to first start it but there is no spark. The distibutor is behind the radiator and is hard to see. Is there a simple way to get to it or check the points or!!! is there an old trick that sometime helps us new comers!!!LOL
Kenny!
Allis1
11-16-2005 17:17:52
 Re: ignition in reply to K L Cullingsworth, 11-16-2005 16:25:26
I believe you could use a mirror to set the points. Good luck
old
11-16-2005 17:23:28
 Re: ignition in reply to Allis1, 11-16-2005 17:17:52
All but impossible to do it that way. no room for any thing in that area on any of the ford Ns.
old
11-16-2005 16:30:57
Its easy to get to. You pop the coil off, and the cap. There 2 bolts that hold it on 1/2 wrench I think. Remove the bolts and the dist comes off, it only goes on one way unless forced. Points are set at .015.
