Restoration & Repair Tips Board
winpower generator not charging
little b
11-15-2005 18:08:17
does anybody now of any simple tricks to get my winpower 20/12 pto generator to work?? i tried turning the drill in reverse trick but that didn't work,, thanks
Logan in S.E. Texas
11-16-2005 21:07:31
 Re: winpower generator not charging in reply to little b, 11-15-2005 18:08:17
I would be very interested in knowing how you come out on this. What solution you find that works, wheather it be one suggested from here or one you come upon yourself. I also think others on here feel the same way about a lot of questions. Thanks.
Jon Hagen
11-16-2005 11:03:51
I have never had to "field flash" my winpower 40/80 pto generator,but have had the field rectifier fail. This is a little 1-1/4 inch square aluminum block with 4 spade terminal connectors and a single mounting screw in the center. The winpower parts guy said the replacement was designed for higher voltage as voltage spikes were destroying the originals.
Try the field flash again with a 1/2 inch single speed drill and make sure the breakers are both on and the drill trigger pulled when you do this. If this fails,you can check your old field rectafier for shorted or open diodes with a VOM. You might also inspect and move the brushes to make sure they are not stuck and not contacting the slip rings.
little b
11-17-2005 19:21:43
 Re: winpower generator not charging in reply to Jon Hagen, 11-16-2005 11:03:51
thanks jon,,it worked after using the 1/2" drill. I'm going to leave the drill hanging on the generator from now on incase it ever fails again
Jon Hagen
11-17-2005 20:30:23
 Re: winpower generator not charging in reply to little b, 11-17-2005 19:21:43
Ahhh,life is good :)
