Restoration & Repair Tips Board
stuck G705
T.Dible
11-12-2005 17:00:05
Picked up a MM G705 diesel today.
Tractor ran year and half ago but is stuck
now. Any ideas!
old
11-12-2005 19:55:06
 Re: stuck G705 in reply to T.Dible, 11-12-2005 17:00:05
Maybe from sitting that long or it could have diesel in the oil which will lock one up. Last diesel I had that was locked up I pulled the injectors and filled the cylinders with turpentine, not paint thinner but to old type turpentine. The next day I put a battery in and hit the starter with the injectors loose. It tried a couple time and moved about 1/4 one the crank pulley I did that 4 or 5 time then is spun over real good. Only problem I had was I ended up haveing to look for the injector that flew out when it spun over. Got the injector pump rebuilt and it purred like a kitten. Used it all summer long baling hay and it didn't smoke or use any oil. Sold it that fall because it was just plain to big for me. 100HP and 40 arces so it wasn't worht it to me.
lanzboy from Aus
11-21-2005 01:34:20
 Re: stuck G705 in reply to old, 11-12-2005 19:55:06
Could also be (at the very worst) water in the sump like the Gvi im looking at buying. This one runs. I dare say that your G705 wont take much to free up if it was running just over a year ago. Good Luck!!
