Restoration & Repair Tips Board
Tractor Voltage
John Borowski
10-30-2005 08:58:50
I purchased a 1956 Case 411 tractor. There was a 6 volt battery installed. When I check the tractor manuel for the model, it indicates that the voltage should be 12 volts. The tractor is equiped with a generator. Is there any way to determine the voltage of the generator? I just checked the coil and it was a 12 volt coil.
Thanks,
John
ronnie269
10-30-2005 10:12:27
 Re: Tractor Voltage in reply to John Borowski, 10-30-2005 08:58:50
there should be a oval shaped aluminum plate on the side of the generator, if not use a multi meter to check how much it's putting out!
