Restoration & Repair Tips Board
Restoration of '49 M
Landon
10-25-2005 17:52:50
I just began tearing apart my '49 M, and am stuck. How do I get the searing column out of the radiator? I just purchased a service manual on ebay, but it won't be here for 7-10 days, and I'm impatient. Please let me know if anyone could help! Thanks!
marlinm51
10-26-2005 04:18:32
 Re: Restoration of '49 M in reply to Landon, 10-25-2005 17:52:50
You have to remove the front grill, remove the large plug from the front of the steering gear housing, separate the front portion of the steering shaft from the rear by removing the front shaft from the knuckle, then unscrew the shaft through the opening in the front housing. There"s a half-moon key in the knuckle portion of the shaft, and I had to smooth the shaft with emery paper to get it through the support bearing.
