Restoration & Repair Tips Board
pre-lubricating a 1947 Farmall Cub before starting
ron and suzy
10-12-2005 21:24:23
We think we are finally ready to start up our 1947 Farmall Cub after a long restoration process. Does anyone have any tips so that we do a thorough job of it? The process doesn't seem to be covered in any of these tons of restoration books we have.
Thanks
old
10-13-2005 13:33:57
 Re: pre-lubricating a 1947 Farmall Cub before star in reply to ron and suzy, 10-12-2005 21:24:23
I'm guessing your talking about the engine. If it was done right there is no need for prelube since it should have been put togeather with it. Any time you rebuild and engine it should have some type of oil put on all parts when put in.
suzy and ron
10-14-2005 10:11:04
 Re: pre-lubricating a 1947 Farmall Cub before star in reply to old, 10-13-2005 13:33:57
Hi,
Thanks for your response. We purchased the remanufactured engine from ValueBilt in the mid-west. Their pamphlet that came with the engine said, "Before starting the engine for the first time, be sure it has been properly pre-lubricated." We just don't know how to check that.
thanks
old
10-14-2005 10:43:31
 Re: pre-lubricating a 1947 Farmall Cub before star in reply to suzy and ron, 10-14-2005 10:11:04
Ok in that case you need to put a little oil in each cylinder. Then with the spark plugs out and the pan full of oil as it shold be turn the engine over and watch the oil preassure gauge. Spin it till you have good oil preassure. If it does give you any reading then you will have to prime the oil pump.
