Restoration & Repair Tips Board
rear crankshaft seal installation
Steven K
10-09-2005 17:06:19
Would someone please tell me the correct procedure for installing the front and rear crankshaft seals? I only want to do it one time.
Thanks
Charles Park
10-11-2005 11:52:04
 Re: rear crankshaft seal installation in reply to Steven K, 10-09-2005 17:06:19
It would be best for you to post this question on the Ford site. I would love to help you but this is beyond me. I know you will find some experts on that site.
Steven K
10-09-2005 17:13:06
I am working on a 1948 Ford 8N
SORRY
Amir Azizi
11-03-2005 07:51:44
 Re: rear crankshaft seal installation in reply to Steven K, 10-09-2005 17:13:06
Dear sir
my rear crankshaft seal is leaking, I want remove flyweel but I am not famoler with klach system in automatic transmission. right now I separeted engine with transmission and need heelp to open the drive weel in nissan sentra 1.6 lit.If you help me in this case I will apriciated. Thank you Amir
BobOHIO
10-22-2005 17:49:48
Steven- crank seals are the rope type. Feed half in the block and the other half in the oil pan. Trim them flush with a utility knife. I put a little sealer on the ends where they meet. Also if I remember right they should be soaked in clean oil for a bit before installation. Good luck.
Steven K
10-24-2005 19:01:32
 Re: rear crankshaft seal installation in reply to BobOHIO, 10-22-2005 17:49:48
Thanks for your help Bob.
Steven
rustyj14
11-08-2005 12:54:27
 Re: rear crankshaft seal installation in reply to Steven K, 10-24-2005 19:01:32
Some of the mechanics where i worked, had a tool that hooked into the end of the upper rope seal,(well oiled) and with much tugging, it would pull the seal around above the crankshaft! I never had one, but the older Ford mechs did. Maybe, in my memory, it seems it was like that woven kids toy, that ya stuck yer fingers into it and pulled, and ya couldn't get yer fingers out, no matter how hard ya pulled on it! the pan seal is easy to replace.
