Screws Wanted
Tugboat
02-14-2002 17:57:08
I'm looking for some replacement hold down screws for the hood on my JD 320 tractor. These are the ones that you push in and turn 90 degrees to hold the hood in place. Airloc 160 is stamped on them. Where can I buy these? Thanks, Tugboat
kevin
02-20-2002 08:52:04
 Re: Screws Wanted in reply to Tugboat, 02-14-2002 17:57:08
you can still buy them from J.D.
charles ethridge
02-15-2002 19:37:23
tugboat, try sportys pilot shop,a mail order catalog for aircraft supplies. charles
John Garner
02-14-2002 19:08:47
Tugboat --
You can probably get what you need through the "fixed base operator" at a small airport, although a good fastener supply house might also be a place to look. The generic term for one of these things is "quarter-turn screw", although the tradename "Dzus fastener" (Dzus rhymes with moose) is commonly used.
John
Tom-Pa
02-16-2002 12:17:19
 Re: Re: Screws Wanted in reply to John Garner, 02-14-2002 19:08:47
Dzus and Airloc fasteners are both doing the same job in a similar manner. But, they are of a different design..Tugboat is correct, the place to find these are at an Aviation supply place..these fasteners were made for aircraft use. But companies have found that they are handy and started using them on other equipment. Airloc 160 is the size and design and there is a dash number that follows when ordering for the lenght from the head to the crosspin.
Good luck
Tom-Pa
Tugboat
02-16-2002 17:23:58
 Re: Re: Re: Screws Wanted in reply to Tom-Pa, 02-16-2002 12:17:19
Thank you guys! Using your advice I found the fasteners I needed at millspecproducts.com
They are Airloc 160 but they are expensive.
Thanks, Tugboat
