Restoration & Repair Tips Board
wheels wobble
samsdad
09-19-2005 18:39:52
I have a A-C model Ca that has a narrow front end, it wobbles bad in high gear. I tightened the outside wheel bearings but it did not improve things. The front sector (towards the steering wheel) has some slop in it like a bearing might be bad. I was wondering if I should that the front wheels off and look for damaged bearings? The left one I turned a quarter of a turn and the right I turned 4 revolutions.I'm new to tractors and I'm a novice wrencher. Thank you!
mdross
10-06-2005 05:15:38
 Re: wheels wobble in reply to samsdad, 09-19-2005 18:39:52
The first thing to look at, is toe-in.Going slow usually is not a problem.My JD 855 was a handful at road speed until I set the toe-in at about 1/4" narrower at the front of the tires.Now it is as smooth as silk.Still cannot keep up with traffic though.
JMS/MN
09-23-2005 21:52:33
The slop usually comes from other sources, but start at the wheel bearings. If they are OK- look at the pedestal bearings, steering arm linkages, then the steering gear. A service manual will ID all of those parts. Running on hard surface roads will show more slop in those parts than running on gravel- just shows what you need to fix next.
samsdad
09-26-2005 18:11:45
 Re: wheels wobble in reply to JMS/MN, 09-23-2005 21:52:33
JMS/MN Thank you for your time and information.I will start at the wheels first.:)
