Restoration & Repair Tips Board
Value of 1934-36 John Deere Model A
TM
09-03-2005 07:57:30
My father and I are trying to determine if we should try to restore his old 1934-1936 John Deere Model A tractor (not exactly sure of the year) or try to sell it as is. What would be the value of this tractor as is (does not run) versus the value if it is restored?
Earl-IL
09-12-2005 21:57:54
 Re: Value of 1934-36 John Deere Model A in reply to TM, 09-03-2005 07:57:30
Check the serial # if it is a 1934 it could be worth a lot . Also what kind of wheels ?? Earl
David from Kansas
09-06-2005 19:03:59
From what I have seen, it will be worth considerably more if it is a 34 or 35 open fanshaft tractor.
BUDD
09-05-2005 10:28:12
TM;
As old said it all depends on the condition it is in now. You can restore and it will be worth more, but it will more than likely cost you more to restore than you can get out of it. I would be intersted in this tractor if you do decide to sell as is (depending where you are located). My son and I are looking for something to restore as a project for this winter. Email me if you do decide to sell.
Thanks BUDD
old
09-03-2005 08:24:02
What its worth right now is propably not much. A lot depends on the tires, how good the sheet metal is etc. Also if the engine is locked up that hurts the value. My guess would be around $200-500 as is. But still only around $3000 max if restored.
