Restoration & Repair Tips Board
need torque specs for the WD45 conecting rod that
mike burvil
08-27-2005 09:45:46
i Have a WD45 and just changed the rings on teh pistons so i would like to know the torque specs for the bolts on the connecting rod that goes into the crankshaft
Ronny
09-10-2005 19:34:36
 Re: need torque specs for the WD45 conecting rod t in reply to mike burvil, 08-27-2005 09:45:46
Mike tighten to 70 ft.lbs considering you have castelled nuts, if you have luglock nuts, tighten to 40 ft. lbs. Remember the wd-45 uses no shims when the correct diametrical clearance of .001 to .003 The piston pin clamp screw to 20 ft. lbs.
Ron
[email protected]
