Restoration & Repair Tips Board
Super A
DPN
08-25-2005 04:42:58
Started my Super A for the first time in three years. Turned over nicely. When I went to put water in the radiator the water came out the botton of the tractor quickly. Any suggestions? Thanks Don
Bob
08-25-2005 05:44:56
 Re: Super A in reply to DPN, 08-25-2005 04:42:58
One possibility, if you have a leak at the rear of the motor... there is a "core plug" (freeze plug, expansion plug, or whatever you want to call it) at the rear of the block, inside the flywheel housing, that commonly rusts through. If that is your problem, the tractor has to be split, and the flywheel removed for access to the plug.
