Restoration & Repair Tips Board
Solid Lifter Face Grinding WD-45
David Nelson
08-23-2005 19:42:11
Is the surface on solid lifters flat or does it taper to the center of the lifter a little? So the lifter and push rods will turn when the cam makes contact.
george md
08-23-2005 21:09:44
 Re: Solid Lifter Face Grinding WD-45 in reply to David Nelson, 08-23-2005 19:42:11
David, Lifters are convex , with a radius of about 50
inches . They can be ground , but you will need the proper radius cut in the side of the wheel.
I do them in a lathe with a toolpost grinder that
has the radius in the wheel.
george
