Restoration & Repair Tips Board
rust removal
trak560
08-04-2005 05:37:31
what is the best way to remove rust on sheetmetal. i dont like the idea of sandblasting because it might warp. do i have to sand it or is there a chemical that will help. thanks
Dan
08-04-2005 06:25:26
 Re: rust removal in reply to trak560, 08-04-2005 05:37:31
Sandblasting will not warp your sheet metal if you use fine grade sand and don't get too close to the metal. I have done three now with excellent results. If you are still dead set against it, get a wire wheel that you can attach to your drill or angle grinder and get the loose stuff off. The LIGHTLY spray some Phosphoric Acid in a spray bottle over the entire surface and let it dry. It will convert the rust and stop it cold, plus leaves a film to help keep new rust from forming. LIGHTLY sand the surface after the phosphoric acid dries and primer and paint.
You can take a look at my website and see what I did with my NAA, I sandblasted AND used phosphoric acid, plus get some hints on what and what not to do with the phosphoric acid application. Click on the "Restoring" link to the left of the page on my website.
Good luck,
Dan
Illinois Boy
08-06-2005 13:57:14
 Re: rust removal in reply to Dan, 08-04-2005 06:25:26
Dan - Amazing...
That's a definite "Well Done"...
