Restoration & Repair Tips Board
overhaul 1953 JD AR, need advise
Rich Heiman
07-24-2005 19:08:57
I am overhauling the engine in a 1953 JD AR. I need advise on the following questions;
What foot pounds of torque should I use on the burs that tighten down the head and also for the manifold bolts? Which side of the head gasket should be placed toward head? The only difference between the two sides is the extra material for the openings to the pistons is crimped on the opposite side that the extra material is crimped for the water port openings!
thanks Rich H
