Restoration & Repair Tips Board
ford 8n hydraulics
Moe Guilbault
07-10-2005 19:19:39
I was recently harrowing my garden and the 3 point hitch stopped lifting. I checked the oil and had plenty. Bought the gasket set and cleaned the pump reinstalled with no success. Anyone have any ideas?
Ken Raby
07-20-2005 09:46:00
 Re: ford 8n hydraulics in reply to Moe Guilbault, 07-10-2005 19:19:39
Also check your draft control lever on the right side under the seat. (small lever)
jwm
07-11-2005 17:38:23
Sounds like the pressure relief valve popped. Take off the right inspection cover and with tractor running in neutral and the lift trying to lift see if there is a swirling of fluid at the base of the pump. If there is it's the relief valve. About $25. James
