Restoration & Repair Tips Board
TD14 clutch stuck
David Hannaford
06-02-2005 21:41:46
Have an old TD14 which will start but the clutch is stuck. Have removed the plate to access but can not see how to free it. Any advice?
Lynn D
08-02-2005 19:41:55
 Re: TD14 clutch stuck in reply to David Hannaford, 06-02-2005 21:41:46
Had the same problem with my MF35 recently and received some advise that worked. If it isn't stuck real bad just tie the clutch pedal down or wedge a 2 by 4 to hold down the clutch pedal and leave it for a couple of days. Takes the pressure off the clutch plate and it may release. Mositure gets in the trans and clutch place rusts to the flywheel. Have also heard the one about getting moving and stepping on the brake but this could also damage the clutch plate. Hope this helps.
old
06-03-2005 08:09:09
Well if it starts up easy you could alway start it in gear and go for a long ride and it may pop loose
mark1952
06-09-2005 10:48:09
 Re: TD14 clutch stuck in reply to old, 06-03-2005 08:09:09
start it in gear and pick a open path hold it wide open and hold in clutch and put brakes on
