Restoration & Repair Tips Board
motor stuck on shaft
jim mall
06-02-2005 16:28:01
been trying to pull motor out of farmall b. it wont let go of the spline shaft. i have heated the shaft but wont let go any help tried everything.
9NJoe
06-15-2005 10:30:30
 Re: motor stuck on shaft in reply to jim mall, 06-02-2005 16:28:01
Jim,
If you can get a wrench on it, go ahead and take the pressure plate off. My bet is that the shaft is seized on the pilot bearing. Take off the pressure plate and then pry it apart with 2x4's, I think the pilot bearing will self destruct and she will come apart. Then have fun getting the pilot bearing race out of the flywheel. I had to use a torch on mine. Just use the oxy lever very carefully and you can cut out the race without wrecking the flywheel.
Joe
old
06-03-2005 08:07:50
Does it move any?? If it moves out enough to get a wrench up in there you could take the oreasure plate loose
xragman
06-03-2005 06:46:27
don't give up. you have't tried everthing or it would be apart.
