Restoration & Repair Tips Board
tire rim leaks
rogman
05-26-2005 06:30:04
New Backhoe tire leaks around rim, poor seal, tubeless. Any tips other than chemicals?
Weirsdale George
05-26-2005 22:07:25
 Re: tire rim leaks in reply to rogman, 05-26-2005 06:30:04
Don't know what you mean by "Any tips other than chemicals"? I and several friends have good luck with Slime (I think that is the name, green colored solution you inject into the tire) for slow speed applications. Add the recommended amount depending on tire size and drive the tractor around for a little while. Works on rim leaks and thorn punctures.
jake3
05-26-2005 08:34:04
Try "no rim rust" it seals, never drys, once applied mounting and dismounting is a snap. I found it at Gemplers.
rogman
05-26-2005 09:05:05
 Re: tire rim leaks in reply to jake3, 05-26-2005 08:34:04
Could not find "no rim rust" at Gemplers online catalog. Was it named Freylube, or Ultraseal?
jake3
05-27-2005 09:39:03
 Re: tire rim leaks in reply to rogman, 05-26-2005 09:05:05
It's No rim Rust possibly Gemplers might not carry it now, do a Google search and find other retailer. It's ggo stuff
