Restoration & Repair Tips Board
deere 210 lawn tractor
nicki
05-10-2005 12:22:38
Recently I cleaned the carb.and now the tractor dies after about 30 minutes.It ran great for a couple of weeks then the problem started.
After restarting it runs for awile then acts like it is running out of gas and dies.
Bob
05-11-2005 00:55:09
 Re: deere 210 lawn tractor in reply to nicki, 05-10-2005 12:22:38
Next time it dies, check for spark.
If you don't have a spark tester, you can take a spare spark plug, and open the gap up to 3/16" or so. Connect the spark plug wire to it, and lay it on a metal part of the engine, or clamp it to a metal bracket, etc, with a Vise-Grip.
Try to start the engine while you watch for spark at the test spark plug. Check that out and post back.
If there is NO spark, it could be a bad coil or condensor that fails when it heats up.
If you HAVE spark when it won't run, it could be a bad fuel pump, or a clogged air vent in the fuel cap or the wrong fuel cap, or possibly dirt in the fuel valve at the bottom of the gas tank.
