Restoration & Repair Tips Board
MF165 lifter arm problem
J David
05-04-2005 12:11:26
I have a MF165 that well to make a long story short ended up rolling down a steep ditch going straight backwards. It had a mower implement on that back at the time. I dropped the mower and got pulled out and I now have a problem that my lifter arms will not work at all.
The tractor runs fine, shifts into and out of all the gears (also using the multipower), the pto seems to work Ok although I have not tested it fully. I have checked the fluid level and although I would like to change it, it is full. (The arms worked fine up until the accident).
The arms are free in that I am able to lift them by hand and when doing so they move in unison.
Could there be air in the system? Do you have any suggestions on how I can fix it?
Please help and Thank You in advance.
