Restoration & Repair Tips Board
ford 800 three point control response
roland hall
04-29-2005 19:07:55
my 850 activates the three point only at the top three inches of its range of movement . can or should the lever be made to follow the three point proportionally through its full range of movement, or is this normal operation?
Joe(TX)
06-20-2005 14:21:34
 Re: ford 800 three point control response in reply to roland hall, 04-29-2005 19:07:55
Check the position of the draft control lever. I sounds like it in the draft position.
phil(va)
05-04-2005 04:08:04
It's common, but not ideal. I don't have experience with 800, but if similar to 600 and NAA there is adjustment in top cover after removal. Check your manual. Top cover is heavy and requires two people to replace, although one might be able to remove.
