Restoration & Repair Tips Board
OIL LEAK REAR OF ENGINE FORD 850
ROLAND HALL
04-25-2005 15:25:28
REPLACED CRANKSHAFT REAR SEAL STILL LEAKS MASSIVE AFTER TWO MIN
ANYONE HAD TROUBLE WITH THIS SEAL AND WAS IT MASSIVE I WOULD THINK IT WOULD BE DRIPPING?
ORDERED REAR CAM GEAR COVER GASKET
ANYONE HAD THIS CAUSE MASSIVE OIL LEAK?
LAST COULD THIS BE A CRACKED BLOCK ?
HAS ANYONE HAD THAT? CAN ANYBODY TELL ME HOW TO PRESSURE TEST THESE LEAKS WITH OUT REASSEMBLING TRATOR?
RickB
04-26-2005 14:19:01
 Re: OIL LEAK REAR OF ENGINE FORD 850 in reply to ROLAND HALL, 04-25-2005 15:25:28
caps lock does not make for faster or better answers. chill out.
roland hall
04-26-2005 15:08:47
 Re: OIL LEAK REAR OF ENGINE FORD 850 in reply to RickB, 04-26-2005 14:19:01
thanks rickb but if sugesting i improve my grammer and cill is the best you can do in regards to this tecnical tractor problem then i will post what i find to my own request when i correct my siduation so as to actualy help someone in the future .thanks anyway. is this what the forum is for ,i misunderstood
RickB
04-27-2005 14:00:56
 Re: OIL LEAK REAR OF ENGINE FORD 850 in reply to roland hall, 04-26-2005 15:08:47
I don't give a hoot about your grammar. Posting the same queation 8 posts apart in two days with the second one in all capitals is rude, plain and simple. Split the darn tractor and look carefully for the oil leak. Cam cover gasket is cheap to buy and easy to change after the tractor is split.
roland hall
04-27-2005 17:35:00
 Re: OIL LEAK REAR OF ENGINE FORD 850 in reply to RickB, 04-27-2005 14:00:56
thanks rick i fell we have started a love hate relationship the second posting was to list in seperate catigory and to alart someone out there in slightly different words, it was never indended to be rude. i am shure my irjent need of experenced machanical help meens nothing to you. i am shure this forum was not ment for this kind of back and forth so this will be my last reply to you
