Restoration & Repair Tips Board
homelite starter cord
will irey
04-18-2005 19:10:07
my homelite weedeater starter cord will no longer pull out, it seems to be jammed. how do i take the weedeater apart to access the cord?
Hermit
04-21-2005 10:08:54
 Re: homelite starter cord in reply to will irey, 04-18-2005 19:10:07
If the problem is that the cord only pulls out a couple of inches then springs back in, the stud that the cutting head is screwed to stuck to the shaft, maybe from dirt or age. You can unscrew the cutting head and the retaining nut to get to the stud. Then loosen it up and put it back together making sure not to tighten the retaining nut too tight. If the cord won't pull out at all, then loosen the throttle grip and slide it forward. There's a clamp under there that needs to be loosened. And the throttle cable disconnected. Then remove the other screws and the whole front cover should come off. Good luck.
TimV
04-20-2005 04:48:17
Will: same thing happened to my Homelite. I"m betting it isn"t the cord--the wrist pin has came loose and is jammed in a port. I ended up having to swap out the powerhead with one from another Homelite a friend had that had fried the head. If it is indeed the cord, you will need a special tool for the clutch, and a torx-head screwdriver for the bolt that is inside the section that hooks to the shaft. If you get the shroud and shaft off, then look inside the piece where the shaft is hooked (basically the outside clutch housing) and there will be a screw at the bottom of this shaft.
frederick f
04-28-2005 06:21:51
 Re: homelite in reply to TimV, 04-20-2005 04:48:17
woul like to let it be known that I have a large selection of vintage Homelite/Jacobson parts available. Just cleaned out shop that was dealer ship for over 50 years. To much to list but woul search for part # per request.
ksp
06-01-2005 11:16:22
 jacobson lawn tractor in reply to frederick f, 04-28-2005 06:21:51
was given an old jacobson. i have no way of identifying it. found a ten diget number stamped on the frame. was told tractor is 1970"s era.any help to id it would be helpful.would like to obtain a manual and some parts. thanks
