Restoration & Repair Tips Board
cattle trailer
mgm
04-18-2005 07:16:15
Some one wants to sell me a trailer but there is problem with it. One wheel is off with just the spindle showing which is slightly bent and there is no drum. How difficult whould it to fix this would any one else have any concerns. What might have happened to this wheel? thx
Joe(TX)
06-20-2005 14:35:45
 Re: cattle trailer in reply to mgm, 04-18-2005 07:16:15
You will have to replace the axle. The other axle probably has problems also. Check the hangers also.
Bob
04-18-2005 10:47:25
The wheel bearings may have failed, and overheated, softening the axle, which bent before the wheel flew off. Or they may have simply bashed the wheel into something, bent the axle, and then removed the wheel, because it was running crooked.
If you are not knowledgeable about trailer axles, you need to find a nearby shop that deals with trailers, and have someone take a look at it, to see what parts are needed, and what the cost will be before committing the purchasing the trailer.
