Restoration & Repair Tips Board
cub cadet 2165 interlock brake and PTO
Paul J
04-17-2005 15:47:18
Hi I hope maybe someone has seen this before. When I am sitting in the seat, PTO off, brake pressed in, it starts and runs fine. Whe I release trhe brake, the engine quits. I removed and tested the brake interlock switch and it tested fine. Now I put in the switch and now all I have is headlights when I turn on the key. No idiot lights either. I hear some clicking but no starting. Also when it ran before noticed the PTO is making a high pitched squealing noise, when PTO was turned on the engine wanted to stall. Any feedback anyone??
Trevor
04-20-2005 19:35:46
 Re: cub cadet 2165 interlock brake and PTO in reply to Paul J , 04-17-2005 15:47:18
check and make sure the switch is hooked up right also you could bypass it by either hooking the two wires together or keeping them apart. The pto could either be bad or just needs adjustment if its adjustable. I would also make sure the kill switch in the seat was in working order. Hope I could help
