Restoration & Repair Tips Board
Sears GT5000 Hydrostatic Problems
Neil A. Runyon
03-21-2005 17:15:43
I have just over 5 hours on my Sears Garden tractor and thought I'd do a little mowing this evening. Things were going great until I hit this stump, which bent the roller thing at the front of the carriage. I can straighten that out and correct.
However, for some reason, now my hydrostatic stick, (or whatever you call it), doesn't match up with the slots. What I mean is that when I put it in neutral, it is still moving forward. It appears that it is off about an inch.
I cannot imagine why smacking into a stump would affect the stick but sure could use some guidance on how to readjust it.
Any tips for this old amateur will be very much appreciated.
Neil
Dennis/Ohio
04-09-2005 02:09:25
 Re: Sears GT5000 Hydrostatic Problems in reply to Neil A. Runyon, 03-21-2005 17:15:43
Hi,
I'll recommend to anybody, I cut my grass at 2" height. My yard may not look as good as the neighbors but I have less tractor problems.
Best, Dennis.....
russ1
03-28-2005 05:22:45
The control lever for the hydrostatic is adjustable. If you will look inside between the wheel and the fender you will see a bolt that holds the lever in position. Get the tractor in neutral, then loosen the bolt and adjust the lever to the neutral position.
Neilrpf
03-28-2005 06:04:13
 Re: Sears GT5000 Hydrostatic Problems in reply to russ1, 03-28-2005 05:22:45
Thanks very much for the information.
Neil A. Runyon
03-25-2005 18:39:27
This is obviously not the place to look for assistance. Oh well, it was worth a try.
