Restoration & Repair Tips Board
One Stage vs. Two Stage Compressors
JKC
03-21-2005 16:07:18
I have been told that I need a 2-stage air compressor for my blasting cabinet. Can anyone tell me the difference between a single-stage and two-stage air compressor? Any help would be greatly appreciated.
steve(ill)
03-21-2005 19:26:35
 Re: One Stage vs. Two Stage Compressors in reply to JKC, 03-21-2005 16:07:18
you probalby dont need a 2 stage, you need a big compressor. a single stage compressor can develop about 130 psi pressure. on a two stage the second stage takes this pressure and bosts it up to 175 psi.--- if you need the pressure that is o.k., but most blasters need VOLUMN. what you need to look at is "what is the cubic feet per minute at 90 PSI" A $300 compressor will put out about 9 cfm at 90 psi. A $700 compressor will put out 15 cfm at 90 psi. A $1100 compressor will put out 20 cfm at 90 psi. What is the requirement of your blaster and will it work at 90 psi with a max of 135, or does it take 150-175 psi with what cubic feet per minute?
old
03-21-2005 17:43:56
single stage slow to pick back up 2 stage more preassure fast recovery
buickanddeere
03-22-2005 23:06:32
 Re: One Stage vs. Two Stage Compressors in reply to old, 03-21-2005 17:43:56
A single stage taking 5HP to drive it would be faster than a dual stage 5HP at low pressures up to maybe 70-90 psi. Above 70-90 psi the dual stage is faster and more efficient.
