Restoration & Repair Tips Board
Rubber Tread for Steel Wheels
Loren in Iowa
03-20-2005 20:20:59
Anybody have a good method to cut rubber tractor tread off the tire, to put on steel wheels? Need advice on how to cut it straight, and make it look nice.
Kirk in PA
03-22-2005 21:11:31
 Re: Rubber Tread for Steel Wheels in reply to Loren in Iowa, 03-20-2005 20:20:59
I used a Tiger saw to cut the sidewalls off. Kind of tough to get perfectly straight, but take your time. It's hard cutting through the lugs. To install, I used carriage bolts after drilling holes with a wood bit to line up with existing holes in the wheels. Use a floor jack and the weight of the tractor to press the tires tight to the wheel before drilling and bolting. I went to a recap place and got tread for the fronts which worked very well.
