Restoration & Repair Tips Board
hot tank
potluck
02-16-2005 18:29:53
How would you build one and what do you use in it? How do you operate it? No, i ain't worried about insurance or the epa.
Don TN
02-16-2005 19:55:21
 Re: hot tank in reply to potluck, 02-16-2005 18:29:53
What I use is a 55 gallon barrel with about 40 gallons of water in it and about five pounds of sodium hydroxide (also known as caustic soda or lye). Add the sodium hydroxide slowly to the water while stirring, or it will tend to clump in the bottom of the barrel. I planned to use it outside where I could build a small fire under it, but never got around to moving it outside, so I just use it inside my shop at normal temperature, which is around fifty five degrees. It works fine for me, but instead of taking a few hours if it was hot, I leave parts in for several days to a week depending on how dirty and coated with paint they are. The sodium hydroxide will eventually be neutralized, so more will have to be added as it is used. Any time you use sodium hydroxide, or lye, be sure to wear rubber gloves, good goggles, and a face shield. Just one drop in an eye can cause major damage. Get a copy of the MSDS for sodium hydroxide and read it before using.
george md
02-16-2005 19:21:12
Potluck,
Send me an email and I'll give you all the info you need and pict's if you want. Here is a link to my web site and the email is in there . >Link
>Link george
dr.sportster
02-17-2005 11:01:17
 Re: hot tank in reply to george md, 02-16-2005 19:21:12
George,I just checked out your site.I think you could say you are like DR Frankenstein.You have brought the dead back to life again.NICE.
george md
02-17-2005 20:04:44
 Re: hot tank in reply to dr.sportster, 02-17-2005 11:01:17
dr,
mouse urine at an eighth of an inch off the
top of that Ed208 cont'l piston , it's done
and I got the fellow a set of rings and Orings
and it's ready to go back to him . Ring set no
longer available, had to make up a set from
open stock.
george
