Restoration & Repair Tips Board
help
looking for hel
01-26-2005 17:22:26
How big a job is it to replace or rebuild a hydraulic pump on a 47 H?
CNKS
01-27-2005 07:42:13
 Re: help in reply to looking for help, 01-26-2005 17:22:26
Haven't worked on a belly pump, have had a couple of live pumps apart. If you work alone you can use a couple of long threaded rods to lower it.
burge
01-26-2005 18:44:01
i don't know about get ing it rebuilt but you will need two people two get it out.
Greasey Hand
03-09-2005 07:03:51
 Re: help in reply to burge, 01-26-2005 18:44:01
There is a large spring that can brake in there,
take 1/2'' round rods & make a T about 8" long & the handle around 12" long, On the end weld a bolt that will stick up past the shaft.
These will go in the lower part of the casting on each side, There is a hole there with a slot in it, have a guy on each side, take the bolts out, wiggle it & out it comes, There is a cross drive piese that will be in there to.
Take the oil pipes out first.
This will be as clear as mud to you but think about it & look at it. Got a fax no ill send you a diagram. Good luck.
