Learning from experience. Had a PTO shaft @ 1 1/8" dia on a really old piece of iron. Bought an overrun clutch that had that input and a 1 3/8 output which is standard today. You can also buy them 1 3/8 both in and out . Didn't like to use it (for purposes mentioned below by others) as it was a loose link in the shaft and on a drag mower when you turned a corner, it made for just that much more vibration. Was baling hay with a transmission driven pto one day and going down hill. Realized that I had to stop the machine as I couldn't execute a tight enough turn to get out of a situation. The implement was driving now (big flywheel revolving and had positive pressure on the pto shaft, which comes out of the transmission, driven by transmission gears and hence had the transmission "locked" in gear. Couldn't get the tranny into neutral; regardless of what I did. Never did that again. Either used one or used a tractor with Live or Independent PTO. Use it and keep it greased. Good luck. Mark
