Restoration & Repair Tips Board
PTO TROUBLE
Ron Milhimes
01-13-2005 08:32:53
I have a 1961 Ford 861 that the pto keeps disengaging. We've replaced the ball and spring in the shifter mechanism. Also we checked the output shaft coupling and it looked OK. There's no play in the pto shaft and there's no vibration when it's engaged. I held a piece of wood against the pto shaft when it was running and it looks like it woobles a very, very, little bit. Is this my problem or could it be something else?
RickB
01-16-2005 03:01:38
 Re: PTO TROUBLE in reply to Ron Milhimes, 01-13-2005 08:32:53
So you already know that it is bent or twisted on the output end. It is most likely twisted on the other end. Spend the $100 on a shaft kit. It buys you a shaft, seal , bearing & retainer with gasket. Put the PTO IN gear before pulling the old shaft out.
Ron Milhimes
01-17-2005 05:50:40
 Re: PTO TROUBLE in reply to RickB, 01-16-2005 03:01:38
Rick: Thanks for your respose, it's always helpful to talk to someone who has doon this work before. I appreciate it.
