Restoration & Repair Tips Board
ford 2000 1962
Malcolm Meijer
01-04-2005 16:11:44
Tractor ran fine over the summer. Tried to start her the other day and she wouldn't fire. I was told the distributor might have pick up some moisture. There was no fire at the plugs. What can I do to dry the distributor? Is there a spray? What about the points, can they be cleaned?
Oldfarmboy Jim
01-06-2005 23:17:27
 Re: ford 2000 1962 in reply to Malcolm Meijer, 01-04-2005 16:11:44
I have a '63 2000 and it did pick up so much moisture one time that it hardly ran. I sprayed the inside of the distributor cap with WD 40 and when I started it back up, it purred like nothing was ever wrong. Nice to see a product that does what it claims. Jim
txblu
01-08-2005 17:14:31
 Re: ford 2000 1962 in reply to Oldfarmboy Jim, 01-06-2005 23:17:27
I'm told that WD 40 stands for the 40th formula tried to displace moisture; hence Water Displacement Experiment #40. Must have worked.
And it does. Really cool if you are in a remote area or something like that and your ign gets a case of the wets. Just spray it good and go.
Mark
