Restoration & Repair Tips Board
MF 135 help
urocyon
12-29-2004 16:39:18
I just purchased a 1971 MF 135. I had the brake on and I let out the clutch. There was a bit of a pop and now the rear wheels will not move, The PTO runs but no go for the wheels. I"m new to tractors and could use some advice. What do you think I broke, ring pinion, axel ??. I have some experience rebuilding auto, how hard will it be to repair differetial parts if thats what it is??
any help appreciated Dave
sibby(Aus)
12-31-2004 14:48:36
 Re: MF 135 help in reply to urocyon, 12-29-2004 16:39:18
Pull the rectanle plate off under the front of gearbox housing and see if the rivets have sheared on your main clutch plate first. If not remove Left hand side cover off tranny housing (6 bolts) with the P.T.O. lever on it, look inside and see if the shear tube has sheared between gearbox output shaft and differential pinion, it is supposed to break before anything major. cheers an good luck. sibby.
