Restoration & Repair Tips Board
WD manifold
Brad W Wi
12-10-2004 06:05:11
On my A/C WD I need to replace my manifold. It's probly the orignal one and hasn't been removed since day one. I'm already worried about snapping off studs. Any tips out there on what a guy can do to avoid doing that?
wdTom
12-27-2004 16:48:59
 Re: WD manifold in reply to Brad W Wi, 12-10-2004 06:05:11
If I remember right at least some of the studs are "wet", that is they screw into the water jacket in the head and you will get wet if you haven't drained out the antifreeze before you remove the studs. With the manifold off,tapping sideways with a punch at the base of the stud may hilp loosen too.
JMS/MN
12-11-2004 01:39:36
They will break off, so grind the nuts off and pull the manifold. Then you have more bolt to work with. With a torch, heat the area on the head around the stud. Turn the stud out with a pipe wrench. Move the stud back and forth rather than just unscrewing. After heating, and the stud does not come out easily, put some candle wax on the stud and let it set overnight. The wax flows between the threads and loosens them.
