Restoration & Repair Tips Board
rust removal by electrolysis
mack jarmon
12-05-2004 11:03:35
I read somewhere in this forum that it's possible to remove rust by using a lye solution and a battery charger. Can anyone give me a detailed procedure for same or tell me where I can find one? Also, is there a downside to using such a technique? Thanks in advance for any help.
Joe M
12-06-2004 17:17:21
 Re: rust removal by electrolysis in reply to mack jarmon, 12-05-2004 11:03:35
Mack, send me your e-mail address, I'll give you plenty to read. Works great, I'm on my second restro. using it
Joe M
12-06-2004 17:18:37
 Re: rust removal by electrolysis in reply to Joe M, 12-06-2004 17:17:21
[email protected]
mack jarmon
12-07-2004 17:00:32
 Re: rust removal by electrolysis in reply to Joe M, 12-06-2004 17:18:37
Thanks Joe. Send whatever you've got. I'd like to read it. [email protected]
Bob
12-05-2004 12:08:03
Here's a link.
1952henry
01-18-2005 06:16:07
 Re: rust removal by electrolysis in reply to Bob, 12-05-2004 12:08:03
I tried this method on a lubester cast iron pump. I was quite impressed. Next week I plan to try it on the steel lubester tank.
Would it hurt anything to use copper wire as the contact between clamp and part?
mack jarmon
12-07-2004 17:08:30
Thanks Bob. I checked out the F.I.T.'s site and printed the pertinent info. I'm doing a 50 JD B and a JD model 52 plow as well. I'm going to try it on some of the smaller parts this weekend.
Big Jim
12-08-2004 00:02:47
 Re: rust removal by electrolysis in reply to mack jarmon, 12-07-2004 17:08:30
Works pretty slick. I recently recovered some internal parts for a Clark transaxle that were in a shed that got wet. Two key principles I discovered are:
Don't get the polarity backwards!
The bigger the battery charger, the faster it works. I have a roll around model from Sears. I cranked it up to where it was running about 30 to 40 amps. Much quicker results than with a 10 amp unit.
