Restoration & Repair Tips Board
Manual for a Tecumseh HH60 6hp on a Troy Bilt
Paul Ward
12-05-2004 08:39:16
My tiller stopped all the sudden and I have no spark. No apparent reason why; the fuse is good but no spark at the plug.
I need a manual on the engine but don"t know where to find one.
Any ideas?
Thanks,
Paul Ward
Ben in KY
12-06-2004 12:34:56
 Re: Manual for a Tecumseh HH60 6hp on a Troy Bilt in reply to Paul Ward, 12-05-2004 08:39:16
I have an HH60 on a Troybuilt. I don't have a manual though. You should be able to get one that covers the adjustments from Haynes.
There is a set of points and condenser under the flywheel. Check those, of course after replacing the plug, they can go bad all at once.
I will check my chiltons small engine manual for the points gap, but I think it is maybe .018-.020. Sometimes the points can look ok but have a film on them which will cause no spark, polishing them with fine emery cloth will fix that. Also the flywheel key could be sheared.
Ben
