Restoration & Repair Tips Board
Thread Sealant
walter squires
11-10-2004 15:02:12
What do some of you use to seal bolts that go all the way through the housing or water jacket to keep them from leaking externaly around the threads, I hate with a passion silicone you never where it goes after it ozzes inside the housing.
Big Jim
11-14-2004 23:58:05
 Re: Thread Sealant in reply to walter squires, 11-10-2004 15:02:12
Permetex #2 is the only thing I've ever used on Chevy heads and water pumps. Never had a problem one.
John Garner
11-11-2004 12:42:18
 That's a job for . . . in reply to walter squires, 11-10-2004 15:02:12
Walter --
. . . a pipe joint compound containing Teflon.
As has already been mentioned, Rectorseal 5 is an industry standard; I've also used and been happy with Federal Process Company's "Gasoila", Radiator Specialty Company's "Solder Seal 55", and William Harvey Company's "TFE Paste with Teflon".
You're more likely to find these products at a hardware or plumbing-supply store than at an auto parts store . . . but that doesn't mean that they don't work very well on automotive engines.
John
bubba
11-10-2004 17:09:33
Rectorseal #5 is the best thread sealant money can buy.
txblu
11-11-2004 12:33:41
 Re: Thread Sealant in reply to bubba, 11-10-2004 17:09:33
If you don't know what that is (as I don't....but maybe O'Riley's has it as they do a lot of engine stuff) Permatex #2 works good. Real thick and gooey, resists petroleum prod and heat, and remains pliable; not soft, pliable. Doesn't get brittle and crack.
Will release iffin you need to back it out later.
Mark
bubba
11-11-2004 18:40:54
 Re: Thread Sealant in reply to txblu, 11-11-2004 12:33:41
Rectorseal is available at Lowes and most other good building supply houses.Sure doesn't look like it will seal anthing but it does.
10.4
11-15-2004 06:41:58
 Re: Thread Sealant in reply to bubba, 11-11-2004 18:40:54
