Restoration & Repair Tips Board
setting up a carb. for an Avery model a
Wink in Wallhal
11-03-2004 13:25:22
I bought a nice model A i cleaned out the gas tank and fuil lines and carb and it run but would die after five min's though it was the carb and cleaned it one more time. still the same so off it came of the thre and forth times. and the is when the light bulb went off in my head and looked to see if the petcock was pluged and low and behold it was got that cleaned out. now the carb is so out of wack it won't stay running to tune it up or just to get it to run. as a rule what should they be set at in order to get it to run. then fine tune from there right?
I just don't know what that is.
Any help would be great
Wink with avery stuck in dive
thanks ;-)
