Restoration & Repair Tips Board
Starter spins on JD60
joshua
10-31-2004 23:51:50
Hey there,
my starter's spinning free when I try to start it. It also makes a high pitch rotating sound. Is the starter gear not connected to the main engine, teeth missing? What do y'all think?
Joshua
Carl NY
11-10-2004 14:05:07
 Re: Starter spins on JD60 in reply to joshua, 10-31-2004 23:51:50
Had a JD 60 with the same condition. The bendix drive was worn out. Have fun getting the starter out.
txblu
11-01-2004 05:14:17
Usually when you get this indication, the power to the starter is weak. Could be battery, or any of the wiring components that make up the battery/starter loop; connections and wiring, or the starter it'self (brushes worn out).
One test, to answer your suggestions, is to remove the starter and see if the bendix operates freely. Then (with a good grip on it) connect the battery to the starter and hit the start button.
The bendix should slam to the end of it's travel on the starter shaft. if it doesn't you have a problem. Then, while it's out, you can inspect the teeth on the ring gear (on the flywheel) for damage.
Should find your answer.
Mark
