Restoration & Repair Tips Board
power steering doesn't work
Mike Sa
09-10-2004 19:57:22
The power steering unit on my 960 ford tractor doesn't work (doesn't provide any "assist"). It doesn't leak, or squeal. Is the most likely culprit the pump, or the cylinder control valve?
I rather not rebuild both units if I don't have to. I got no responses when I posted the same question on the Ford tractor page. Hopefully one of you all will give me some clues.
Jon H
09-12-2004 16:19:31
 Re: power steering doesn't work in reply to Mike Sa, 09-10-2004 19:57:22
Check the pressure relief valve in the pump, if a bit of metal trash has it stuck open,the steering will react as you describe.
