Restoration & Repair Tips Board
john deere 214 ; battery keeps going dead
roaddog
08-31-2004 15:11:18
I have put three different new batteries on it and all went dead. Does anyone know what might be causing this. Thanks Jerry
bubba
09-01-2004 07:19:18
 Re: john deere 214 ; battery keeps going dead in reply to roaddog, 08-31-2004 15:11:18
A bad isolation diode could be the problem allowing the current to flow both ways.
Bob
09-01-2004 07:47:49
 Re: john deere 214 ; battery keeps going dead in reply to bubba, 09-01-2004 07:19:18
This is a Kohler engine, no isolation diode, outside of diodes in voltage regulator, which, as I posted earlier, is probably cut off from the battery when the ignition switch is shut "off".
JMS/MN
08-31-2004 21:53:30
Along with the advice from Bob- consider this- you have a leak somewhere. How long does it take for the battery to become dead? Several days? Took me almost a year to find the leak on a 3020 tractor. If I used it every few days it was ok, but a week or so, it was dead. Turned out to be a worn spot in the battery cable under the dash. Noticed a small spark one night while starting it- the cable cover was worn a bit and was shorting out to ground.
Bob
08-31-2004 20:22:51
If it goes dead while running, your charging system isn't working.
If it goes dead while sitting shut off, I would look for a defective or incorrect ignition switch. Also, if it goes dead while sitting, I would try unhooking the voltage regulator upon shutdown, and see if it still goes dead. It is possible, though that the regulator is disconnected from the battery when the ignition switch is shut "OFF", providing the switch is working properly.
