Restoration & Repair Tips Board
cracked block on farmall SMTA
marty
08-11-2004 18:01:38
I have a SMTA and there is a crack in the block right behind thr carb it leaks oil so I put JBweld on it but it still leaks yet what else would work? any ideas?
Red Dave
08-12-2004 12:19:05
 Re: cracked block on farmall SMTA in reply to marty, 08-11-2004 18:01:38
Since you said it was leaking oil, I would guess that it may not have been clean enough when the JB went on it. JB Weld is good stuff, but surfaces have to be completely clean.
I would try it again, but use a chlorinated solvent such as Brakleen (several applications, then let it dry) to get all oil out of the crack.
marty
08-13-2004 10:47:38
 Re: cracked block on farmall SMTA in reply to Red Dave, 08-12-2004 12:19:05
I will try it again thanks for the reply
